View the entries in the address map control tab to see which host interfaces are enabled for monitoring on the switch. Each entry in this table enables the discovery of addresses on a new interface.
  1. In the navigation pane, expand Configuration > Serviceability > RMON.
  2. Select Address Map.
  3. Select the Address Map Control tab.
Address Map Control Field Descriptions
Use the data in the following table to use the Address Map Control tab.
Name
Description
Index
Shows a unique identifier for the entry in the table.
DataSource
Shows the source of data for the entry.
DroppedFrames
Shows the total number of frames that the probe receives and drops but does not include in the StatsDropEvents value. This event can occur if the probe is out of resources and sheds the load from this collection. This value does not include packets that were not counted because they had MAC-layer errors.
Owner
Shows the entity that configured this entry.
